Man I just went through this on a customers truck. Did the same thing and had the same code. The cac had a hole inside it. I replaced with new one problem solved.
There are a few of us with stock Intercoolers kicking in our basements as well if you decide to go that route haha.
So, put air pressure to the CAC while heating it up and it's leaking. But only leaks when it's hot.
Tony helped me check it at his ford dealer he works at, but we couldn't find it when the cooler was cold. Took it home and threw it on the cooktop till it got to 250degrees. Low and behold the POS was leaking then.
6.0tech(Tony) is hooking me up at his dealer to get a new one. He's TOP NOTCH! Thanks again Tony for everything!!
I'll update this after the new one is on.
Pics of my homemade Air leak setup lol
Zipties are to keep that piece on. I now have a hole in my garage ceiling lol.
Glad to hear you found the leak! A lot of the time they gotta be cooking hot to leak. My buddies 05 duramax will only eat coolant when it's hooked up to the holiday trailer and heavy pedalin. He's still trying to find the damn leak ahaha. Can never get it on the pressure test when it's cold or Luke warm...
Don't you just hate those stupid leaks.
No limit cac?
Is that what he went with or oem?
No limit cac?
Ah sorry wasn't paying attention to the last few posts so my reply was out of context, Sounds like he went with stock.
Was able to get my stocker warrantied. Can't beat free... One day a IC from Mike will find its way in there.
Absolutely! That's cool that they covered it.
A more efficient cac will cool air better but will put more strain on the secondary system because it transfers more heat.
ive yet to hear of any leak or issue with the system from one of ours. has yours leaked other than blowing gaskets ?
