stacked6.7
- Joined
- Jan 21, 2013
- Messages
- 305
- Reaction score
- 0
I lost weight in 2013 lol.
Basically something happened within the last 2 months. I'm just trying to figure out if a factory cac will last towing with my setup, or if it will blow as well. Or if in 2 years another factory one will leak.
Ford won't find the leak without heating up the CAC(I used my electric oven and got it to 150degrees )that's when mine started to make bubbles.
So, ran the truck hard this weekend and got the secondary to puke AGAIN. I think I got the CAC to leak again. I guess the factory CAC can't take sustained high psi (high 30s)
OR my thermostats aren't working? I'm thinking the CAC is leaking again though, it stopped puking towing after I installed the new CAC. Will keep you guys posted.
I've built and raced a number of Nissan Z cars over the past 15 years. We use a coolant breather system to remedy these problems with a lot of success.
https://conceptzperformance.com/gre...type-n-fits-most-japanese-vehicles_p_8682.php
As far as aftermarket radiators, I always preferred CSF and ran them in two of my cars with great results. Plus they're made in the USA and not some cheap crap like Mishimoto made in Chinese slave camps. I've heard nightmare stories about their cheap thermostat's failing and causing thousands in engine damage on subarus, nissans, etc... I had one fail on my 350Z many years ago. I'm actually sad to see they made their way into this market.
CSF press release on superduty radiators:
http://csfimports.com/the-only-oe-style-ford-super-duty-radiator/
I thought the issue we are having is with the intercooler? If they are leaking from factory defects or from high boost pressure I'm not sure a breather is the best answer.
i'll hook you up if its a direction you want to go. i know you'll test it proper .
I read number of comments about air bubbles in the system, radiators and the fact that you are running more boost and straining the stock system, which lead me to my reply. The breather tank moves the hot and cool liquid through the system way more efficiently.
Anyone else checked the thermostat yet? I have a new one on the way and a long tow for the holiday weekend so I'll know if it helped or not.
just an update. I put in a new thermostat, it looks the same as what I originally pulled out, there is a gap at the bottom so I assume they do that for a reason? Ill try and post some pictures of what I'm talking about.
The other thing is the secondary cooling system only holds about a gallon of coolant, I am wondering if when you remove the egr cooler if that doesn't effect the capacity of the cooling system some? Im thinking about adding a tank or something where the EGR cooler was to add a few quarts to the system and maybe act as a heat sink as well.
