The Broke college kid project log
Renegade7.3
Loudonville, OH
Oil change the other day
ReplCed the blower motor resistor my fan now works in all speeds !!
Before
After
Found this beauty the other day while inspecting my brakes
My parking brakes. Thus may be why they don't work lol
My friend is coming over Sunday and we are gonna run a cylinder contribution test and figure out what two cylinders are dead on my cold Starr cause that's what we think is why she won't start without being plugged in cause I have new glows and relay
You can do anything you want, as long as you don't break rule #1
Renegade7.3
Loudonville, OH
because the caliper was bad on the one side they decided to block it off with this method....
I had to put a new line on it with new fitting and here is the finished product
now some exhuast pics
size comparison
Just waiting on the videos to upload now
Renegade7.3
Loudonville, OH
What exhaust did you go with? How was the fitment?
sorry for long time sincei was on
It is a AFE aluminized.
It fit good. the DP was long so the trans X had to be removed to install on my zf6.
The truck has a bad MAP sensor it reads 1.4V at all times and supposed to fluctuate between 1.9-2.1 at idle and .3-.5 at WOT
was playing with stack ideas today also
i like this one the best
this is just another one i found
Snowman
TN
You probably have batts. In there already but dual big rig bats will fit just have to grind the tray a little and change one end to clear the hood
Renegade7.3
Loudonville, OH
Been thinking of making a box and mount them in the corner of the bed or modifying the under hood mounts for them since they are so tall.
I've done a recent amount. I'll update later tonight for y'all
Colin, E99 F250 7.3 6spd 4" turbo back straight pipe, Autometer boost and Pyro, 340,000 miles
Renegade7.3
Loudonville, OH
i havent updated yall in a long while.
well i did finally graduated college!
working full time.
but with the truck. iv but all new steering parts under it. put 33's on it.
been trying to fix why my tcase wont shift.
currently also shopping for injectors. thinking just remans or stage 1s from powerstruck with the customer service he has given me so far.
here is a recent picture of the truck. sorry for the bumper i also mashed a deer a month ago...
TyCorr
Injectors. Then what plans do you have? You gonna keep going or move to.a different vehicle altogether?
mandkole
Northwest
working full time.
Good for you-- you working in a shop now?
Good call on stage 1s--they are an easy transition for injectors. IMO, but unless you have a plan to really step up and invest in many areas, no sense in going larger right now.
Renegade7.3
Loudonville, OH
i have plans on keeping this vehicle for a long time if i can get the bugs worked out
well i ended up getting just reman ADs cause funds and i really need the truck back on the road and starting.
for now my plan is gonna be convert to l99 intake with a 38r, t500 from joey, tunes, and regulated return for fuel system.
maybe down the road ill upgrade injectors again. but right now. i need it running and starting again
Mts678
Nice. I can't wait to upgrade my hpop and get a 38r and do a RR too! Keep up the good work
Renegade7.3
Loudonville, OH
I GOT MY INJECTORS IN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
install went fine. I highly recommend Justin at Power-Struck. super friendly on the phone. and sur eit took awhile cause parts got backordered. even for the deal he gave me he went the extra mile to ensure i got a premium set of injectors that work flawlessly and not throw together some injectors with half a$s parts.
so far so good. just been idling more than anything here for an hour or so. if you punch the throttle you get that white raw fuel smoke. im figuring its from air and what not in the HPO system and fuel system.
lots of oil coming out the exhaust but everytime i have done injectors this has happened, i pin it up as nothing and it just needs ran
TyCorr
Ive nwvwr had thaaaat much oil. I get grey **** for.the first two.wot runs then it cleans right up.
