Truck Pull Questions??
bdm1981
Salem, Missouri
I'm going to hook up the truck tomorrow night so I have a few questions for you guys that do this quite often. Truck is bone stock. 3.31 gears. All other info is in my sig. Stock tires. What gear should I pull in and should it be in 4hi or 4low??? Any input would be appreciated.
08Monster
4low, 3rd gear, strap the front end down if possible, ease into it and roll out 15ft or so, and floor it. Proceed to hold it floored unless you get a bad bounce or stop moving.
Sent from my XT1585 using Tapatalk
PDT1081
Bowling Green, OH
So 20psi front 60psi rear?
For a first time hook, I'd probably go with 35 and 70. You don't want your rear tires to squat too much. You'll lose hitch height.
Can you hang weight and block suspension?
bigrpowr
<How I Fly
What this guy said Ben.
