Wheel/Tire Tech Thread
wanna_b
Those nittos don't look bad stretched. Might look into them when claws wear down.
smokedout250
harrisburg oregon
Ok gonna be buying wheels this week! I really wanna run a -24 so my tires stick out.... I'm running a leveling kit and want 35s but idk if I can pull it off for a bit until I can get a lift or not these are fuel hostages 20x10 -24 with 5"bs
STR8LINE
Barren River Lake, KY
I am Running the 20x12 Fuel Nutz wheels with -44 os and 35x13.5 Tires man.. 3+1 level'in kit!! I would post some pics but dont I havent opened a new account somwhere too host them yet.. If you want I'll e-mail you some though. The Did rub a some so I trimmed my truck a little bit, but its Not noticable
smokedout250
harrisburg oregon
For str8
Jeff@Spartan
Georgia
I only hav a 2.5" leveling kit and I don't think they will clear...
I know it's a 2008, but I am running 20x10's with -19mm offset and 35/12.50 MT's at stock height. The only time I get rubbing is on the drivers side if the truck is flexing a certain way. I would think you would be fine with a 2.5" leveling kit but then again I don't know how different the fender well size is on your truck compared to mine.
smokedout250
harrisburg oregon
Well I have been told no it won't work, and then I have been told its dang close then there is the pics I posted up a bit ago and he is running way wider than a -24 and he is clearing other than the inner fender
Jeff@Spartan
Georgia
I zip tied my fender liner back. It won't rub as long as I'm on flat ground. My leveling kit and bigger rear blocks go on Wednesday, so I shouldn't have to worry about it anymore no matter how much the truck flexes. I hope anyway.
STR8LINE
Well I think I'm gonna truths wider SET I can ways lift it lol
Hell Yeah!! Thats what I said.. an I ended up outa cash an cut my truck a bit for now, I orginally ordered 14" wheels tho and Thats what I really want and Iam gonna buy coil springs an shocks an build a custom chromoly suspension an ladder bars for the back
smokedout250
harrisburg oregon
Where did you cut and how bad do they rub and where do they run?
AKHILF
Eagle River Alaska
Its just the plastic inner fender. Once you get your wheels and tires on you see what you need to do. I ran 20x10 -24 fuel hostages on a leveling kit. It rubbed slight at full lock till I pulled the inner fender back and I just put a self tapping screw to hold it.
smokedout250
harrisburg oregon
Thanks! Your full of good info!
smokedout250
harrisburg oregon
I think it will be close but I plan to lift it when the cash is around so if it don't work I'll throw them in the garage and wait for the lift to show up!
STR8LINE
I couldnt wait after bolting them on!! lol
Seriously tho, I Cut the bottoms of the fenders behind the tire.. Not much you cant even tell it unless you bend over an look close I didnt mind as Iam building a custom truck but its personal preference..
Now, Alot of that is because I went with 12" wheels and part of it is because I went with 13.5 wide tires... and Unfortunately today I figured out that I Think I have a bent tracking bar, I dont know for Sure yet but unless a stock bar has a bend an curve in it at the bottom end, then Mine is bent! If it is bent I plan on ordering some stuff an building an adjustable bar! I think in theory if I go any taller it would need too be longer anyways?
Rightnow I think the axle is sitting offset too the center of the truck a bit too the drivers side where the bar is bent and its shortened in length.. The Drivers side was the worst By Far at rubbing too!!
