will 22x10.5 rims with 35x12.50 fit with just a 2.5 leveling kit on a 2008 f350
jmd2422
hey guys i got a 2008 f350 with 20x9 bmf wheels with no off set and 35x12.50 and they do not rub at all with out a leveling kit so if i put in a 2.5'' leveling kit with 22x10.5 bmf wheels with 35x12.50 tires do you think they will rub the bumper or painted fender?? if they rub inside the fender well i can pull it back or cut it but the rims backspace is 4.50 in i think has anyone done this?
jmd2422
im not sure if im in the right thread im am trying to figure out how to use all the diffrent threads and the right places to post
cfdeng7
CT
my buddy clears 35x12.50 on stock 20s on his stock height 250. There are a few guys on here with similar setups as well. You should be fine.
jmd2422
ya but the problem is the offset stock offset works with stock rims or 0 offset i guess this offset stick out 4.50 inches more it would maybe hit going buy the fender
jmd2422
i have 35x12.50 now with 20x9 bmfs and they dont rub with no leveling kit what do you man bigrpower unless the offset is jacked up?
Corb@CorbinShipping
Autryville, NC
Highly doubt it unless the offset is jacked up.
what do you mean eric you doubt they will fit your saying?
sorry the off set is -25 and the backspace is 4.75
Like mike said, if the offset is huge, then the tires will hit something. I run 20 x 10 BMFs, with 325/60/20 nitto terra graps (35.5 x 13), and a 2 inch BDS level kit. BS is 4.75, and I had to cut the fender skirts a pretty descent amount. They didnt touch the painted fenders, nor the bumper, but they rubbed the skirts, bad. your rims sound the same as mine, but 1/2 inch wider, so, you might have to do what I did. But you shouldnt hit fender at all.
jmd2422
ok sounds good i got the 2.5'' level kit with 2.5 in long ranch 9000 adjustables maybe the extra half in will help a little bit ha
jmd2422
i just want to make sure because i already ordered the tires and rims and ordered the shocks and leveling kit but if i had to to a 4.5'' lift i would return it all before i open anything
PTSUPERD
Offset on a BMF 22 x 10.5 is crazy. I'd go bigger than 2.5" lift and 35s.
I know my truck has different fender openings but it indriveable with the same combo:
powerstrokin15
Charleston, WV
mostar is running a 22x11 monster 35x12.50s on his leveling kit. -44mm offset
and im running a 20x10 throttle 35x12.50s on stock height. -24mm offset.
i think itll work with some trimming and work awesome. if not you can always go to a 33" if they will handle it on a 22"
Matt
Minnesota
Another fellow on here was running the same 22x10.5 bmfs with 33s and stock height, he didn't seem to have a problem. I'd say with an extra 2.5 inches of lift, you should clear pretty easy.
Jeff@Spartan
Georgia
Aaron Rudolf had 22x10.5 Novakane's on his crew cab, slammed on the ground, with Nitto 420S's. I know it's not 35's, but the truck was lowered.
jmd2422
the 35x12.50 are sitting in my garage soi cant go to 33s nowhte rims are back ordered and i already have 35s i cant down size and 33s on a 22 in wheel leaves like no tread the offset is -22 and 4.5 or 4.75 back space if your running -24 eric then my should def fit
jmd2422
ya ryan from bmf said a 6 in lift to run those and i dont want a 6 in lift thats if your wheeling i assume but i dont offroad my truck
powerstrokin15
Charleston, WV
well thats what im saying. im running the same setup essentially-on stock height although yours are .5" wider
people at fuel told me i need 4" to do my setup.. i texted him a picture when i got em mounted and he was suprised
