6.7 Twin Turbo Setup
Dan
Fort McMurray AB Canada
Was the air to water just not performing well enough or was it purely the fitment issues?
Under normal heavy acceleration the system would become head soaked and boil over pushing all the coolant out of the secondary cooling system. Expecially after doing all those doughnuts... So yeah that frozen boost was putting too much load on the secondary cooling system... Air to air is the only logical way to cool my intake air temps
4EverBoosted1
I may be wrong... But it seems like the passenger side of the motor will be getting no air at all...
jcain
Both sides of the motor are plumbed in, albeit not the smoothest transition to the passenger side. Pressurized system don't care.
Isobaric
Navier-stokes would disagree with that statement....
Sent from my XT1060 using Tapatalk
Isobaric
Not saying it won't work for a temporary solution...just wouldn't run it like that indefinitely. Especially with the power you are pushing. Air temps aside I've seen some nasty chit happen when cylinders aren't breathing equally.
Mike@MPD
Pasadena,MD
Is this big enough?
Dan
Is this big enough?
Mpds "prototype" if you wanna call it that, air to air setup is on the table... Just waiting to hear back from Craig on cost and time frame...
I was also approached by a long lost friend about a twin mishimotto/ custom rad setup which I am strongly considering...
That one in particular mike looks like 5.9 Cummings and if I remember correctly it's not the factory rad being used... (Likely a good thing due to failure rate)
TRUBBS
Balls Deep
i think its an HTT polished 3rd gen if memory serves me correct
