40-45 mph hop/vibration issue
SDS97_7.3
Finksburg, Maryland
What I don't understand, if this hopping issue is so prevalent on these truch, why hasn't NTSB looked into it?
Is there a place where one can look up this issue if it's so common?
Billy T.
[email protected]
Because not all do it, mine only will on certain roads, under certain conditions at a specific speed. But I can't see the body flexing like Jake can on his, just a slight bounce on mine, like riding on an old concrete highway is what it's like. But only for about a 3mph spread
JMart
DFW
My CCLB doesn't do it. I have just under 7k miles on it, and the only time I get any hop is on a new stretch of concrete highway they just opened up. Its less than 1 mile and I have to be going close to 75mph to get it to buck. But that is the harmonics of the highway vs the length of the truck. Not the truck itself. I am rarely going 75 through there since its a 60mph zone so I don't have issues but every time I go through there at over 70 I have to slow down. Other than that I never have this issue people are talking about. I also opted against the FX4 package, less weight and different shocks. I run with a mostly empty bed too. There is probably less than 100lbs between the toolbox and its contents. But I never saw anything before I put the toolbox in.
my 12 didn't do it either at first. i think it started around 15-20k miles...
Layson
Any chance you could take a picture of the driveline. The end connection, then at the carrier bearing and at the transfer case.
not sure if it matters or not but the drw trucks sit about 2 inches lower then srw.. angles might differ
To add. I get ZERO hop. Bone stock suspension. I also got ZERO with the CARLI lift I had before.
Also, I only had a 45mpg hop ONCE. A weight fell off the tire. I had to tell them to balance it twice to get it perfect.
Has anyone tried road force balancing??
cuz short box..
i have beads in my tires. smoothest they have ever been. even better then the factory Michelins...
even with a bent rim
cuz short box..
True, have you tried new shocks yet?
gnxtc2
Bergen County, NJ USA
Does it hop?
I would like to see some pictures. Thanks
I drove it out of the dealership on Oct 30 and have driven it probably three times. I have 499 miles on it. Sometime I wonder why I bought it.
I have not felt a hop nor have it been paying attention for it. Never knew about this issue.
I have the truck on the lift to paint the rusted, bare metal parts (driveshaft and steering components). Hopefully the Rustoleum doesn't affect the balance on the driveshaft. [emoji10] . I'm also replacing the Ranchos with Fox 2.0s.
My friend has a '15 F250 CCSB with the 6.2. I asked him if he felt a hop on his truck and he said "No".
Billy T.
[email protected]
Layson
Billy T.
[email protected]
I might have missed it but your dually is a CCLB right?
gnxtc2
Yes sir
Billy T.
[email protected]
Mhatlen
Dorrington & Elk Grove California
Bracing absolutely stopped it on my truck
Yeah I don't think the bracing will get rid of the hop. That may improve slightly the handling but that's it... the frames are plenty strong in these trucks.
I looked at a cclb truck the other day that didn't have the hop and it had a different driveline then normal....
Installing that setup on my SCLB absolutely cured the hop. Plus made it drive like a Mazerati. My current truck doesn't have the bounce but I installed a new set because it makes such a difference in how it drives.
Layson I can assure you it stopped it 100%. I'm installing a setup on a guy that's local. He felt that I overbuilt the bracing and that tying radius arm brackets into transmission crossmember would be all that's needed.
It wasn't.....it significantly reduced it to a few cycles before canceling it out. We are going to finish going all the way back to the frame rails.
I will post up the results and I'm sure the forum member will to since he frequents on this site.
