UNLIMITED_DIESEL
What using inferior orings can do... Anyone want some fuel in their oil???
https://vimeo.com/132578896
hey, you are missing something...Driver's side is done and installed. Taking a lunch break and knocking out the passenger side.
Rusty
lol.. yeah, those are always fun to find when you are trying to make sure the washers didn't fall back in the cup..I found the missing copper washer on the ground. The missing parts of the o-rings are eveywhere!
Rusty
rubber mallet or palm fist them.. lolThis was the worst injector.
All of the injectors are reinstalled. It sure is tough to seat them all of the way with the extra metal ring in there. Just need to finish replacing the leaking water pump that I found while I was in there. Then I can fire it up.
Rusty
Well, the truck started back up and made good HPO #'s. But, I stopped after 20 miles of driving and still 10-15 seconds to start. I figured I'd put another 30 or 40 freeway miles on it. When I got off the freeway, I pulled over, shut it off and tried to restart it. No dice, never over 400 psi until the 5th attempt and got her home. Tried pulling the ICP pigtail off the sensor, it starts after 3-4 seconds. Plug it back in, and now starts after 3-4 seconds, no difference from unplugged, but better. The ICP pigtail is hammered, insulation looks worn and I see some copper strands. I'm going to replace the pigtail and hope that's it.
Rusty
