oneturboforme
- Joined
- Sep 12, 2011
- Messages
- 1,040
- Reaction score
- 0
Anyone know of a company who does this.. also does anyone know of a company who checks hpfps.. thanks
Supply is about 15psi...
I did have it regd on both sides but took it off, worried it was part of the problem.. so I have the airdog strait to the pump and I have a fitting right above the hpfp that reads 15psi.. thanks for the 450psi tip that will help me move in the right direction... Must somehow habe an airbuble... I will keep trying to bleed the lines at the heads.. even tho I have done that about a dozen times and only a light strewn comes out when cranking
Nope.. don't get that code.... Should i be bleadinf both the hp lines at once or one at a time... Been doing one at a time..
