Time for more air... 71mm vgt & 86mm S510
Its a vgt I got from elite should have it next week depending on when will gets his truck back lol
Will I haven't got it yet if your comming thru next Friday or so ill have you haul it up here for me
Cool jd that's fine
Will just let me know if not ill just have tadd ship everything
Heavyhaul
Wyoming
Shawn called me before I could call him. He said the truck should be done end of next week but the turbo parts are not in his hand yet. Idk. Guess it all depends on the parts showing up on time. Is yours finished?
Jhaddox
Negley, OH
Awesome project Dustin...i wish i had the skill to make my own set up...id have a bunch of welds lookin like a little kid blew his nose on the pipe and a huge cluster ****
props for sure on it...good luck
Thanks guys going to start tomorrow ill post some pics but tomorrow will mostly be a teardown day so don't expect much from me lol
Matt
Minnesota
Good luck Dustin. I look forward to lots of pictures, cause I would like to set up a set of compounds in a similar fashion, just need to find someone that can weld. Curious why you went with a 71mm instead of one of Tadd's 66mms if you are worried about spool up. Unless you plan to go quite a bit bigger with your low pressure in the future.
This is what I got done today
And this
The reason for tge 71 is ellerton od using one with good luck. A local truck runs the 66 and spools great still so I figured a 71 would be ok. Might have a litter lag I can deal with some if I'm making power in trade but I think it will spool decent
jdgleason
Fort Collins, CO
O man... project is goin fast! There is a ton of room in that wheel well. So Im not clear on your downpipe route... Are you going outside of the frame in the wheel well or staying inside?
CAT35niner
NJ
Dustin do u have the oil drain figured out yet? I wanna do this remote mounted turbo like u and been tossing around the idea of using a oil drain sump like they use on some high end cars. Having a catch can and a pump to bring the oil back up to motor might be a way to go and have a pressure sensor in the line to make sure all is well.
I think the best place for the oil drain is going to be in the rear sump of the oil pan at the top, its fairly easy to get to and i think i could weld it in if need be, i think thats where im going to try and put it.
As long as the drain is above the oil in the pan it should be fine anywhere right?
There was a little thread and debate about the oil drain being above the oil level, thats all im worried about is poking a hole in the oil pan and striking oil LOL
6.0dirtworker
Cloud 9
LOL At least you didnt drain your pan then drill :doh:I dont know what I was thinking,at least it is high. I guess ill find out when my s4 is blowing seals or scorching?
