1995 cclb restoration and build
Strokersace
Towanda, KS
No... For the supercrew you are thinking about the 01 and newer crew cab half tons. Super duties are reg cab, extended cab and crew cab
You're right about the 1/2 ton Supercrew's. But the SD's are regular cab, SUPER cab, and crew cab.
GM's are extended cabs. Dodges are quad cabs.:clapping:
Following your tread man. Will be watching this one. You planning on doing anything with the rust on your rocker panels?
swamp_ratt
hudson, wi
Yes, replacing the whole thing. Also replacing above the windshield on the passenger side
Mwilbur516
Great thread. Can't wait to see how it turns out. Was the engine runnin' when you pulled it? the pistons looked a little loose.
swamp_ratt
hudson, wi
Yeah, nothin recent has happened in a while. Got some other things going on and tryin to get a cummins sourced and built for it as well as source an eaton rt6610 trans
swamp_ratt
hudson, wi
got the bed and doors back on. Still needs body work but ill wait till its running so i can take it over to my grandparents shop to use the good welder. The box will have to come off to replace the floor supports. Getting there slowly. The head for the new motor is almost ready for port and polish. Need a few specialty tools first. Hopefully be able to pick up the new donor motor soon.
Sent from my EVO using Tapatalk! Snootchie Bootchies
swamp_ratt
hudson, wi
well the new motor is down to shortblock. had to pull the driver side head to have 3 glow plugs drilled out. gonna get 14 mil head studs and cometic head gaskets. was gonna try to get it set in this weekend but have some other things going on. besides still waiting on my transmission. should be doing wiring here soon so as to get it all to work together. will post pictures when the new motor is resting in place!
swamp_ratt
hudson, wi
well, got bored and impatient tonight. That combined with some nice weather, i drug it in the garage and set the motor in. Now time to build some motor mounts and figure out wiring!
swamp_ratt
hudson, wi
a few more from tonights efforts
swamp_ratt
hudson, wi
A few more since i got a chance to take some nice daylight pics. As seen in the back of motor shot... Plenty of room for the allison!
swamp_ratt
hudson, wi
And a few more. fits in there very well. Need to make motor mounts now! Obviously i have some paint touch up to do!
