Show me what you did with the fuel cooler deletes
Sahrens0202
OH,WY,ND,CO
How did this turn out? Do you have pictures of the whole fuel cooler delete process? I will be doing this when I put on my lp system and just want to know what I need.
08BIGRIG
WI
I am awaiting a fitting that comes on tommarow for the regulator. I needed a o-ring boss plug and nobody is open on weekends around here. Should be here tommarow. My setup will be a little different because I have the fuel bowl delete or the air dog upgrade.
Sent from my iPhone
-Jerry Bruley-
08BIGRIG
WI
Parts came in but I am still working as we speak from 6am this morning.
Sent from my iPhone
-Jerry Bruley-
91turbogsx
Gardner MA
Those tube to AN fittings will work. You need to cut the line as close as you can to the end where it turns into a soft line or else you will not have the room for it. Best pic I have..
B585Ford
WV
Looks very clean. On a side note, is that the 1200 degree header wrap on the up pipes?
HOOV3R
Central PA
Anybody delete the fuel cooler and pump completely, hooking the vgt actuator cooling to the engine cooling circuit?
08BIGRIG
WI
I did not delete the fuel cooler but I would not be opposed to it if I knew the temps would stay in check. I am running a unregulated return now and that seems to work pretty good. Returns back to the tank not the fuel block.
Sent from my iPhone
-Jerry Bruley-
ncollins64
winchester springs, tn
pics
This is the work that Morgan done. Its elites stage 2 lpfs with a custom cooler delete. The return is also unregulated feeding a cooler underneath. So far I'm pleased with the kit, it is very clean and thought out.
HOOV3R
Central PA
Sent from my iPhone
-Jerry Bruley-
I'm planning on making my own unregulated return fuel system, with a frame or bumper mounted fuel system, returning back to the fuel cell. Just would like to get some of the crap out of the engine bay.
