6.4 crank no start. Mpd s472 amd code p0232
San Antonio Tx
No fuel pressure sensor, but I fixed it... got a exhaust leak..... lol but at 3k can't even see 10 psi lol!!! This trucks a head turner though....
But back to motor works, the blow by.... its able to push the cap around when loose...
Dzchey21
wyoming
Where is the exhaust leak?
I would say the blow by is excessive might also be the spool issue
Sent from my SCH-I545 using Tapatalk 2
Dzchey21
wyoming
If you have low compression that will make it hard to spool. ..
2500 feet should be just fine.
Get the leaks fixed and let us know
Dzchey21
wyoming
Pistons can look fine but you have low compression due to the lack of cross hatch in the cylinders. Thats what blowby is lack of cylinder compression.
I hope its not that but based on what youve said so far you have something going on
San Antonio Tx
Dam... would be ashamed if I just spent 6k on a piece of ****... these got to be something I can do to see... remember its just enough to make the cap blow slightly off... its not thrown like when you cut off the ccv flow..
