Wayne
Elite injector nozzles come with injection lines. Tow powers come with install gasket kit. A new injection pump cover gasket comes with the lines from the pump to the rails. Ford recommends replacing the gasket any time it is removed. The wires in the cover gasket are prone to failure, especially on gaskets with lots of miles. Wire failure = engine not starting, and turbos back off to change the gasket. Unless you do custom tuning to decrease PW, you will see a significant increase in egt's constantly with that turbo upgrade. Even then, you might see higher than acceptable EGT's. You'll never be able to use those injectors to their maximum capability without a whole lot more air. Those 60% over nozzles are serious overkill for what you have. 60 HP, not 60% are recommended for the tow-power combo. 60%, or 110 hp nozzles are ideal for max-power turbos (way larger). Although those are recommended figures, more power capability is possible with oversize injectors, it is a trade-off of higher egt's and excessive smoke.Thanks, I will have to look up the part # to see what all that is when I get time.
I just got off the phone with Ben at Rudys, he is a nice guy. here is whats on the way.
EDE studs and gaskets
EDE ported rails
airdog and upgrade
mpd 60 nozzles
pump to rail driver and passenger line
rail to injectors lines
intake and exhaust gaskets
turbo install kit
egr delete with w/gate
Ben is checking on wait time on the tow power
he has the II turbos in stock.... what yall think about them?
also he cant find the bag of parts pump but has the II pump. what up with the II pump? some no some say yes
Good? sure they're good, but are they better than the billet precision wheels that are already included with the turbos to begin with? All precision vs. batmowheel testing we've done suggests you'll lose power by going with the batmowheel over the precision.batmwheels for tow powers be good
Custom tuning will be crucial with big injector nozzles and stock pump. The DIY bag of parts, as mentioned before, is not available yet.Live tuning would be a good thing to add to the build and maybe a cam...
What are you doing for the trans?
As for any advice from me, in a daily driver you may tow with, I'd prioritize air flow over increased fuel capability to get power with good EGT's. I'll be doing the ported intake, double billet tow power turbos, (no limit IC pipe and elbow already done) 4" down pipe, and when it's available, the bag of parts injection pump upgrade. Also plan on ported rails, airdog II and fuel bowl delete all with stock injector nozzles and custom tuning.
For years, duramax guys have been running 3.2+ ms pulse width, and the most I know of 6.4 guys running is 2.25. My theory is unproven to my knowledge, but if it isn't done before I get to it, I'd like to see just how much can be done with stock nozzles to keep minimal smoke and EGT's at sub 600 hp levels, and have solid power when I do sled pulling or screwing around. If increasing the pulse width doesn't work out well, then I'll go back to dropping 60 HP nozzles in. Food for thought at any rate.
