Show me what you did with the fuel cooler deletes
capt dong
Houston, TX
at what point is a fuel cooler delete appropriate? i wouldnt mind tidying up the engine bay and possibly adding a better cooler but seems like most of the fuel cooler deletes are on moderate to heavily modified trucks.
TRUBBS
Balls Deep
wondering the same thing
HOOV3R
Central PA
There isn't really an appropriate point, it is mainly done to tidy up the engine bay or to make room.
CT9AIX
MA
Another idea too. If you have your egr system deleted, MPD now makes the coolant plugs with -10 threaded ports. You could use those for your feed/return for the VGT cooler
Badland
New Mexico
So is this all we need to do to delete the fuel cooler?
Just have a hose made to connect the 2 together or is there more in depth that iam not seeing?
I really want to do this delete to clean up the engine bay
groove
Okanagan BC
Wondering the same
nickw226
somebody should make a kit to do a complete fuel cooler delete. Might be a good money maker. My fuel cooler pump never comes on. And im in the hot south.
CT9AIX
MA
return line. that looks like a MPD regulated return kit so that line goes to the regulator
TRUBBS
Balls Deep
so is this as easy at it appears or am i missing something?
looks like you just remove the cooler and splice 1 line together?
