Wheel/Tire Tech Thread
jameson731
johnson city, ny
01 f250, leveled on 20x10 weld dakars -25 offset i believe with 35x12.50r20 trail grapplers. Very Slight rub at full lock on passenger side leaf.
jameson731
johnson city, ny
My old wheel setup 01 f250 stock height 22x9.5 rockstars +12 offset with 285/55r22 terra grapplers. Rubbed leaf springs hard, and fender liner. Sat a little sunk in from fender lip
Gear Head
NC
Wheels are moto metal 962 in a 20x12 it looks. An like a 305/50/20 nitto terra grappler. Truck looks beautiful with that setup.
That's what I was thinking, thanks! I just picked up a charcoal beige metallic 06 and am thinking about doing chrome since it looks so good on this color. Trying to decide between these moto metal or hostages. Might try a 305/55/20 duratrac too
diezelfreak
Manchesthair tn
Yeah the chrome will look good on there. I love the color of your truck wish my 04 was that color instead of the damn green an tan king ranch colors lol.
jdolliver
22x12 on 33s on a 2001 f350
Will 33s on 22x12s clear stock heigh or will I need level or lift ?
Mesa, AZ
Ive got an 04 with an add a leaf in the fron about 2in. It clears 35s no problem. Offset or backspacing or whatever will be a major issue. I got my rims for free and ended up with a 9/16 spacer to not hit the leaves. A leveling kit will only help with fender clearance, rim choice will be what will clear the leaf springs.
jdolliver
Not worried about rubbing leafs just wondering if 12 wides -44 offset will rub the fender or bumper sticking out so far.
jdolliver
Doing xd grenades all black 22x12 -44 offset with nitto terra graps 33x12.5 want them stuffed in there like this picture im going to post
black'n'blue
They're gonna rub. I had 32" tires on 22x12 -44's and they were stretched on the rim. That was the only way they would fit without rubbing. Forget about hitting a bump in the middle of a turn
Sent from my SAMSUNG-SM-G925A using Tapatalk
black'n'blue
That's what a lot of the stock height guys are running. Usually a -22 or -24 offset I think but don't quote me on that. I rub 22x12 -44 on bumpy turns with a 6" lift, cutout fender flares, and 325 55's. Plus I even trimmed inside the wheel well
PABowhunter
So if Im wanting to do 20x10 and 305/50, what offset should I run? -12 or -24?
What is your suspension setup? I'm assuming it's the 2002 in your sig that's on leaf springs.
My truck has x code springs up front and I clear a 305/70r16 on 10" wide wheels with -24 offset.My tire is a tick taller than a 305/50r20, but everything else is equal as far as clearance is concerned. My tires do stick out a little. The -12 would bring them in about 1/2".
Upstraydog
Liberty indiana
Ok I'm new to this thread but hears a question I have a 2008 f350 6.4 with stock 20s I'm wanting to get wheels an tires I'm looking at fuel 20×10 24mm with 35×12 tires will this combo rub stock height
Lipka101
Maryland
Probably will a little. Should be able to tie fender liners back to clear.
